Forum Navigation
Forum breadcrumbs - You are here:ForumGeneral: Introductions3D file loading issue
You need to log in to create posts and topics.
Dear Team,
We have Masso g3 controller in which once we download 3D Gcode file then it will take around 15 minutes for loading.
The G code program file size is 450Mb.  We have test many different files but controller takes more time for loading.
Do you have any solution for this?
waiting for your feedback.
450Mb is big, is this for some engraving job because the file is very big?
A file this size will take some time to generate the entire preview but you don't need to complete the preview all the way to 100%, press escape to exit preview generation. then you can start machining your job from the F2 screen and masso will run the entire file to the end even if you have skipped the preview generation.
Ok thanks for your feedback.
we will try and let you know if any query.
